sealant?
Old Jul 31, 2006 | 01:14 PM
welshgrouser's Avatar
welshgrouser
sealant?
in the shop manual, when reinstalling the right side crankcase cover, it says to apply sealant to the mating surface.
question: what kind or type of sealant should be used?
any help would be appreciated...
i'm replacing the water pump seals...
Old Jul 31, 2006 | 02:42 PM
Scooberhawk's Avatar
Seņor Miembro, Ay Caramba
My mechanic friends like Yamabond.
Old Jul 31, 2006 | 02:43 PM
shayne's Avatar
Make sure you use a specialist gasket grade automotive sealant. These are resistant to fuel and oil etc. Readily available at your auto store.
Old Jul 31, 2006 | 02:59 PM
jschmidt's Avatar
jschmidt
The mechanics friend is Threebond 1105.
Old Jul 31, 2006 | 05:07 PM
Yamaha Bond is what I use on all 2Stroke case halves and gasket areas like the VTR has,, right over a case split
Old Jul 31, 2006 | 06:40 PM
welshgrouser
thanks for the responses....
in the manual there is no mention of any locktite to any of the bolts?
should i use locktite or a similar product on any of the external bolts after the repairs are done?
Old Jul 31, 2006 | 07:24 PM
jschmidt's Avatar
jschmidt
No.
Old Jul 31, 2006 | 08:23 PM
Originally Posted by jschmidt
No.
add a yes to the answer list
I use one type or another on most all fasteners.. If you use the light strength, then what you get is corrosion resistance, and a anaerobic thread lock that resists loosening from vibration. Which will come out with hand tools and no chance of damage to fastener or item fastened. BUT ONLY USE THE LIGHT WEIGHT STRENGTH locker on the M6 fasteners in aluminum.
Med or high strength thread locker is used also, where appropriate.
Or safety wire all fasteners that have fluid behind them
Old Jul 31, 2006 | 09:36 PM
I've had great results with Hondabond HT, which I'm guessing is the same/similar to Yamabond. I used it on the oil pan amongst a bunch of other times. It was about 18.00 and actually ended up getting it from the Acura dealer after the bike dealership didnt have it nor did the local honda dealer.
Old Jul 31, 2006 | 10:43 PM
superbling's Avatar
Dude,
As per what I said in another recent thread, take great care in aligning the waterpump shaft when putting the cover back on. Compared to what can happen if you get this wrong, gasket sealant is the least of your worries. BTDT. :-)
Bandit400man
May 16, 2012 01:31 PM
