SuperHawk Forum
-   -   The RR (https://www.superhawkforum.com/forums/technical-discussion-28/rr-12530/)
Doc Aug 30, 2007 08:14 PM
The RR
I am having trouble with my speedometer. It stopped working today, then started again during my ride. I searched the forums and saw several posts regarding checking the RR or R/R; however, I am stumped as to what this means :confused:. I have been working on my own bikes for years, but this is a new one.
Thanks
marmaladedad Aug 30, 2007 08:18 PM
The reference is to check the voltage on the regulator/rectifier to make sure it is still operating correctly. You'll need a voltmeter to do so.
Randman Aug 30, 2007 08:20 PM
Marm, a father??? Holy crap monkey's, when did that happen?? Congrats!!!
Doc Aug 30, 2007 08:26 PM
Thanks. I will check it out in the manual. Everything seems to be working great on the bike...
It sounds like the R/R fails periodically...?
marmaladedad Aug 30, 2007 09:28 PM
The OEM r/r is reputed to fail pretty frequently. I replaced mine with an Electrex (now Electrosport) r/r. Some people do NOT recommend this company, but I've never had a problem with their product.
I believe other r/r's from other bikes will fit, and should be a lot cheaper to purchase.
Thx Randy. :)
redman Aug 31, 2007 05:56 PM
I stuck an Ebay R1 unit on there.....no probs, lots of fins, big alloy heatsink body, 30bux.
superbling Aug 31, 2007 07:27 PM
Check the speedo' plastic drive nut in the front sprocket cover. Hopefully that is wearing out (they do) since they are only a few bucks.
It's electrical if the dash (clock, trip) resets.
