which rotors will work on rc51 front wheel?
will my superhawk rotors work? they look close and mine only have a thousand miles or so on them
which other rotors will work on a 2002 rc51 front wheel i have a 2001 rc51 front end |
Nope. I believe they have different bolt spacing IIRC. Not sure about diameter and offset.
A good way to check compatibility is to download EBC's pdf catalog from their website. |
I don't think the VTR rotors will fit as they are smaller in diameter (296 vs 320 mm if I remember correctly). 929 rotors will nto fit either as they are larger (330mm, again, going on memory). I would suggest you go and post this question on the Speedzilla forum in the RC section, some very knowledgeable chaps there too
cheers |
