Recognize this needle?
Old Sep 7, 2009 | 08:41 PM
Hawkagain's Avatar
Hawkagain is on a distinguished road
Further evidence that my "completely stock" Superhawk is not! Does anyone recognize this needle? I was wondering whose jet kit it came from.
Thanks,
Steve
Old Sep 7, 2009 | 09:00 PM
RK1's Avatar
RK1
Hard to say with the clips obstructing view of the grooves. How many grooves does it have?
Dynojets have 6 grooves, I think FactoryPro has 5.
Old Sep 8, 2009 | 01:23 PM
Hawkagain's Avatar
The needle has 5 positions. I have never seen a stock superhawk needle but this one has a big change in diameter at the sharp end. I guess that would effect the upper half of the power band which isn't a bad thing.
Steve
Old Sep 8, 2009 | 02:28 PM
killer5280's Avatar
It doesn't look like the needles in my DJ kit.
Old Sep 8, 2009 | 03:58 PM
RK1's Avatar
RK1
Steve
If it has five grooves, it's almost certainly a FactoryPro needle. Check the main jets, report what they are and you'll be well on your way to getting informed advice on what to do.
Old Sep 8, 2009 | 10:32 PM
Just_Nick's Avatar
Who are you?
That's a FP jet kit. I'm going to go so far as to guess that your bike will have a 172 front/175 rear main jet, and #50 pilot jets.
PS, remove the shims that are under the c-clip. Those are pointless.
Old Sep 9, 2009 | 03:32 AM
RK1's Avatar
RK1
Yeah. The fact that they are there is proof that whoever set up the carbs didn't know what they were doing. Better go through them from start to finish.
Old Sep 9, 2009 | 12:20 PM
Hawkagain's Avatar
I thought the shims seemed silly. I just wanted to remember what was in there and put it back together. The guy I bought the bike from swore it was stock!
Thanks for the input.
Old Sep 9, 2009 | 12:35 PM
trinc's Avatar
1 flat washer needs to be under the clip & the other washer may be a 1/2 clip position adjustment...
whether you put it back the same way would depend on how it was running.
+1 to it's a factorypro needle.
tim
Old Sep 9, 2009 | 01:27 PM
RK1's Avatar
RK1
tim
Re; the washer representing a fractional equivalent of a needle groove-
Either the PO was a highly sophisticated tuning genius or he didn't know his *** from his elbow. If the bike isn't running right, put your money on the latter.
Old Sep 9, 2009 | 02:20 PM
From looking at it, the fact that the washer equals about ½ a groove each, with two there he could just have moved the clip... I'd put my money on the latter option...
Old Sep 9, 2009 | 04:37 PM
Perhaps you folks shouldn't be so quick to judge in regards to the washers under the clip. I know, for example, that there is a kit sold called the 5/20 kit which allows you to fine-tune your needle position (one needle position being equal to 0.040", the shims went from 0.005" up to 0.020"). In fine-tuning my bike, I experimented with different washers and shims (including a plastic washer sold by Yamaha for some of their sleds, 0.016"). I am currently running one washer under my clip (0.032") in order to get the needle right where I want it but had played with different set-ups (including two washers) on the way to ending up where I am now and beleive me, if you tried my VTR, you certainly wouldn't think I was crazy or had lost the script. Now, without knowing more about the size of the washers involved in the pic, it could be that the PO was doing some fine-tuning (although more info is needed to be sure).
Old Sep 9, 2009 | 05:19 PM
I agree that you can use washers to fine tune... No mystery there...
My assesment was based on the visible thickness of the top flat washer being about the same as the distance between grooves... But agreed, a caliper is waaay more accurate than my eyes on a picture...
Old Sep 9, 2009 | 05:35 PM
stebbdt's Avatar
COBB Member
Hey Mikstr, fun vacation? Well, I finally got around to tearing my carbs down for a cleaning & check up, and go figure, I find five groove needles, clip on third from top with a washer under the clip, #50 pilots and 178 & 180 Front/Rear, I've just begun to get familiar with my hawk (2.5 Mos), and searched the forum to see where I was at, looks like the pilots may be a bit fat, but, the bike pulls like a freight train, the plugs are indicating a little toward the rich side, but, I'm leary of fussing with it cause it runs so strong.
LOL, if it ain't broke..
Old Sep 10, 2009 | 01:22 AM
Just_Nick's Avatar
Who are you?
tim
You mean on top of the clip, right?
Old Sep 10, 2009 | 06:22 AM
trinc's Avatar
No, on the bottom. the PO of my bike installed the factory kit and imo did it correctly ( at least it ran very well ).
i assumed that the factory instructions has you place 1 flat washer UNDER the clip as mine is the same way.
anybody have the factory instructions ???
tim
Old Sep 10, 2009 | 08:52 AM
I do at home as I have an uninstalled kit. However IIRC it is very light on details. I am actually debating just taking the bike in to get it installed rather than doing it myself due to that fact.
Old Sep 11, 2009 | 12:18 AM
shayne's Avatar
A washer should be installed under the circlip at all times. It is supposed to be there regardless of jetting spec.
Old Sep 11, 2009 | 12:53 AM
Just_Nick's Avatar
Who are you?
Why? That raises the needle half a clip-space.
Old Sep 11, 2009 | 06:55 AM
trinc's Avatar
imo, it keeps even pressure on the clip & gives the needle a better surface seating against the slide.
the stock needle has the same washer. iirc.
tim
Old Sep 11, 2009 | 11:10 PM
shayne's Avatar
Honda use these washers standard, for what reason I do not know. Perhaps it helps with sealing as it is a solid surface where a circlip is not. Perhaps it helps the needle to rotate. Who knows.
But jet kit installations advise you to retain them.
Old Sep 12, 2009 | 09:40 PM
Just_Nick's Avatar
Who are you?
There is a spring on the needle retainer, and I noticed play when I did not install the washer.
996Riders
Aug 23, 2010 10:24 PM
hawkbill
May 8, 2007 06:12 PM
killer5280
Dec 23, 2006 10:32 PM
EngineNoO9
Mar 16, 2006 07:32 AM
ff
Mar 9, 2006 05:12 PM
