SuperHawk Forum
-   -   rear wheel alignment? (https://www.superhawkforum.com/forums/technical-discussion-28/rear-wheel-alignment-8648/)
welshgrouser 05-06-2006 12:18 PM
can someone shoot me a photo (www.welshgrouser@hotmail.com)
of the rear wheel. from the back on the sprocket side>>
i am wondering if the sprocket side, side collar, should be flush or sticking out (away from the hub)?????
i did an alignment and i ended up w/ the outside edge of the front wheel being almost 1/2 inch off. i know the rear is not at an angle and in alignment. my left side collar is sticking out from the wheel and it's hard (impossible) to tell from the photo's in the manual if it is supposed to be..
thanks in advance..
marmaladedad 05-06-2006 06:33 PM
You're talking about the spacer/collar that looks like a hat, yes? It will stick out a little bit from the sprocket, but I've never had issues with alignment.
welshgrouser 05-06-2006 10:04 PM
that's the part..... now that i think of it, it wouldnt help me anyway... the front needs to come that way not move away from it (which would've happened if the collar(little hat) needed to be flush...
guess i'll mount everything up agian and do the alignment over...
if anyone has anythoughts let me know...
thanks
sprhawk neil 05-07-2006 07:46 AM
Re: rear wheel alignment?
what part of MI. are you in? are you going to the blessing of the bikes in baldwin may 21? And welcome by the way.
marmaladedad 05-07-2006 09:08 AM
And the front wheel is installed correctly, too?
