Rear sprocket hub dampners
I have approx. 1/4 in. or more free play movement on the rear sprocket hub assy. and know it's worn but, what symptoms are felt with worn torque scrunchers. I ask only because the tire is new and the chain and sprockets are so so. However, if it's drastic I'll replace them.
Thanks. |
do it
do it....'s'only 25bux
Makes the throttle feels much more connected to the rear wheel...go figger |
I would say replace them also... Just had my rear wheel off for new tires and they were still snug at 7100 miles.
Mine are sloppy as sh*t, probaly a half inch. Just got new one's yesterday, with a new chain i'll be putting e'm on tommorrow.
Spray the damper rubbers with silicone spray and clean the hub thoroughly. I have 41k on mine and they look like new. Spray them every time you change your rear tire.
Thanks, I think I'll replace them soon.
Deffinatly made a huge differance, i would recomend it.
