rear shock spring rate
hi everyone
new to form what great info you guys have the stock shock so the book says is sprung for 180lb rider does anyone know what this translates to in spring rate looking at buying an aftermarket shock on ebay and it says the rear spring is 900lbs and I have no idea what this means in rider weight. also I added pic of my hawk to profile when I post it dosnt show it under my name like others do |
jason54
racetech.com put in bike type year etc Put in street or track and your weight and it will spit out what spring rates you'll need. Make your choice and send in money. |
the spring rate is based on bike+rider+gear+riding style.
i have a 1k spring @ 180 lbs give or take and set aggressive ( track ) the preload adjuster is in the upper range so my guess a 900lb spring would be good for around 150 lbs rider. tim |
I went to race tech web site and they dont even list the vtr1000 in
thier list of bikes. the shock im looking at is on ebay and its a fox racing shock. The stock emoltion single adjust shock on my bike leaked the fluid out while the bike sat on my lift for some time and I wanted to upgrade so I bought a rc51 rear shock for the double adjustablity and with the proper provisions made it fit the bike but the spring rate was about half enough for that bike so after you respring it and revalve it you are not far from spending enough to buy used after market. |
that's weird. i found it... go to search, spring rate search and select what you need. It's listed under street, then honda, then VTR1000F
http://old.racetech.com/evalving/Spr...ork&bikeid=267 go there. put in your info and go for it |
Also do a search for F4i shock mod, to see what JD can%
Ya, the race tech "find what we have for your bike" works great.. (it is a VTR1000F in case you wondered)
and according to them the stock rear shock spring rate is: 16.4 kg/mm |
The stock shock spring is indeed a 16.4kg/mm (918lb/in). I calculate that as being good for a 161 pound rider. Here is a table that I've put together that might help you with spring rate selection:
Rider = Spring Rate 95-130lb = 850lb/in 130-165lb = 900lb/in 165-200lb = 950lb/in 200-240lb = 1000lb/in 240-275lb = 1050lb/in If you want the Metric rate just divide the lb/in value by 56 and that will give you kg/mm. I hope this helps! |
thanks everyone you guys are great info
how do I get it to show the pic of my bike under my screen name like everybody else? |
Click on "User CP" then "Edit Avatar".
Rex |
yes
I painted it and did the airbrushing my father and I have a shop in atl area we do custom paint and airbrush as well as sport chopper conversions |
| All times are GMT -7. The time now is 09:14 PM. |
