Radiator Coolant Hoses
Old Jun 25, 2004 | 08:23 AM
john2kvtr's Avatar
john2kvtr
Has anyone pulled off the radiator coolant hoses from the carbs? I've been on the list for a long time and don't recall much talk of it.
My mechanic shimmed the needles to .0435", adjusted the a/f screws to 2.5 turns out and set the TPS to 610 ohms (needs to tweek the tabs for lower). The bikes is kinda cranky until warmed up and then the off idle or low rpms is not good. He's going to try bending the tabs on the TPS to get it down closer to the "factory" setting.
Any suggestions for the off idle, slow warm up and the radiator coolant hoses?
2000 Superhawk 996
K&N filter, bafflectomized exhaust & worn out rear Pirelli.
Old Jun 25, 2004 | 02:38 PM
john2kvtr's Avatar
john2kvtr
Update: I sync that syncing the carbs might have resolve the problem.
Old Jun 26, 2004 | 07:54 AM
john2kvtr's Avatar
john2kvtr
Here's a reply I got from the email list.
John,
While it does sound like a good idea to remove the coolant lines, leave them on. I tried it in '98 and ran the bike for around a year that way and then put them back on. The bike defantly runs better with them on. Greg N. also did a dyno run with the lines removed and made less power. Part of it is due to the heat helping atomize the fuel in the large throttle bodies on the S/H and also the thermostate is a two starge design which stops the flow to the carbs when the coolant temp. reaches a set point ( I don't recall the exact temp.)
Also you should go back to the stock air filter. I ran a K&N for a long time and it was always far more trouble that it was worth.
Mike
hawknator
May 18, 2011 07:03 AM
Torque Junkie
Jun 16, 2009 08:17 PM
3D02
Oct 4, 2006 08:53 AM
superbling
Aug 27, 2006 02:56 PM
faz
Jul 29, 2004 10:58 AM
