quick question???
I'm ordering my cct's right now do I need to order valve cover gaskets also, thanks in advanc,Neil
Yes! Remember, two of everything. :)
thanks marm. I ordered them with every thing else
Whoa
Are you sure you need "valve cover" gaskets?? CCT gaskets yes..but valve cover are those not re-usable o-rings????????
Dave |
No, valve cover gaskets are not required. They are reusable 0-ring type. What you need are new gaskets for the CCTs. That's all. They should be like $1 apiece.
I read that as the CCT gaskets. Hmmmmm....
oh well they were only 37$ for both gaskets I knew I had to pull the covers off to alighn the int. exh. on the crank so I guess i'll put new ones on.thanks to all I'm sure once this starts you'll hear from me alot!!!
