question for another 1999 owner
installed rear wheel after tire replacement and noticed a small gap between the left rear spacer flange and the bearing dust seal . Everything lines up and moves fine just looked a little odd to me . Just wanting someone to look at theirs and confirm , I'm guessing a 1/8 inch gap . Thanks
The spacers are different lengths and if you get them in wrong this is just what happens. Look at the online micro fiche (I use Ronnie's Mail Order.com) and make sure you are properly reassembled.
The left spacer is entirely different so thats not what I'm talking about , front ones are different widths .
Was it just a tire replacement or did you replace the bearings and dust seals. I ran into a similar issue after replacing my rear tire, bearings, and seals on my 98. After assembled I noticed a gap like you are refering to on the left side where the spacer goes into the dust seal. Called the supplier and turns out they had put a wrong seal in the kit.
dealer just swapped the tire for me and no other disassembly that I know . Let them look at it and they said it was alright . Do you not have any gap between flange and dust seal now ?
Last time I had my rear tire off I got the spacers fukt up and when I reversed them I realized that the spacer on the inside of the wheel had shifted as I got the spacers wrong. A little wobbling back and forth and the spaces went away and every thing was tight - no spaces. You can get to the internet microfiche can't you? If you have an internet connection and don't know how I can walk you through it.
I have a manual , just wanted someone to look at theirs to check this gap before I took it apart .
OK - I'll go look.
Thanks, waiting to hear . :shock:
I have no gap in between the spacer and inside edge of the dust seal. But they sent me the correct seal and my problem was solved.:)
Thanks, we are talking about the flange part of the spacer that goes against the inside of the swingarm , correct ? Thanks Also did your wheel line up and roll ok with the wrong seal ?? Thanks
Yes, we are indeed talking about the same area, and yes it lined up correctly when assembled. The spacer was sitting up against the inner race for the bearing and the inside of the swing arm. On the stand there was no wobble, I didn't put it back on the road until I had the correct seal though.
I'm really puzzled , I'm kinda thinking the guy put the bearings in wrong or put some new parts that were wrong in after mounting then tire . I'm gonna ride it back over there and have them check it again . Thanks
Probably be the best thing to do. Good Luck and keep it rubber side down.
Originally Posted by kd1659
(Post 61956)
Thanks, do you remember any gap ? I'm not sure its worked out since I can't find a bike to look at . I'm gonna take some pics myself and see if folks can help .
I have pics now but have no idea how to post here !!
1 Attachment(s)
After you hit the reply button you can type your reply. Then scroll down to "manage attachments" Choose to browse for the image. Navigate to where the picture is stored, highlight it, choose open. Then choose "upload."
This is where is can get tricky. The file size can be only approx 90Kb in size and if it's bigger the server will not be able to upload it. If this is the case you have a couple choices. Probably the least painful is to sign up at Photobucket.com (free) and then cut/copy/paste the link into your response. The other way is to post to the forum gallery and then tell everybody what your album name is so they can go there to look at it. The other method is to use you picture manager and reduce the size of the photo to below the 90Kb size and post in your message. Then it will appear like this in the body of your message. |
Thanks I'll try
Pics on the way , Thanks
spacer pic
Anybody want to see pics just send me their e mail so you can compare to your bike . Thanks
2 Attachment(s)
OK, guys! These are the pics that kd sent to me and I resized them so you could see them. He (smarter than me) put a little red grease in the space that he's talking about. My bike has the same space.
I misunderstood, I thought he had a gap around the spacer and the inner lip of the seal. I also have the gap you are refering to on my 98. Great idea with the red grease. Really made it jump out. :thumbsup:
Originally Posted by Hawk9807
(Post 61987)
Thanks for the help fellas, now I can continue scuffing in my new tires !
:winner:
:draggin: :headbang:
