Please post Year and Miles of CCT failure
also, any anecdotal thoughts as to warning and mode of operation at crux point, thanks! We need a statistical mean:nerd: for folks to get er done...!
:search:
I've got about 13.5k miles on my bike without a failure. I've had some cam chain noise when cruising under very light load since 5k miles. It hasn't gotten any worse/louder in over 8 thousand miles. I was gonna wait 'till 16k when I need to do the valve clearance, but now you guys are making me nervous.
PS bike is an '03 purchased new in '05 |
Originally Posted by nuhawk
(Post 185580)
:search:
Searching is fine, but I think a new thread dedicated to people listing model year, mileage and CCT failure, or noise, or no problem is worthwhile. |
and a thread that does not get 'jacked
Heard the rattle at 44k miles, got home parked it, and replaced the cct's so I didn't blow up the motor, and thus can't 100% say if it was really "the noise" or not. Also looks like previous owner may have replaced the rear one, but not the front, but can't tell for sure. Either way it was about time I would say.
I replaced them both at 21K for good measure. Then at 38K the front one failed.
I am waiting on my APE CCTs from UPS as I type this. Come on Brown! |
With all this I'm freaked I've got my legs wrapped around a ticking time bomb. The APE CCT for the Superhawk is the same model as for the CBR1000RR, is it not? So- do Honda I-4's spontaneously burst into grenades as well? 27.8K Miles on my bike, just ordered APE's yesterday.
2004 33k on OEM's. No noise but still changed them.
I have 22k on mine & am planning on changing them this winter. no noise but you guys make me nervous. My son's cbr900 needed a cct at about 30k. went bad with no warning.
'98 with 22k miles, starting to hear a slight rattle at lower RPMs on and off. Wanting to replace them soon, but $ and wife are limiting factors.
Failure at 18k, replaced with new oem's at 30k now, I'm running it till it dies now. I guess i was lucky, I was idling up my driveway w/ the choke on fiddling w/ my mirrors somehow just jumped timing and didn't annihilate anything. I know other makes and models that have very similar problems too. Honestly the manual ones sound good but I guess we'll see about the "updated" Honda ones!
Mine went bad at 17k. Since then, No problems whatsoever from the ape mcct's.
I forgot to mention I got mine cheap as a recovered theft that had been ragged out till the battery jump they did to steal it blew a fuse! I love this thing though, I'll never buy anything but a twin or triple.......cheers.
Most everyone is not indicating the model year of the bike that had a CCT fail. I think we are trying to find out if certain years are more prone to fail than others. Maybe it would be better to have this as a poll for the year then we can follow up with details on the mileage?
Originally Posted by motojoe
(Post 185628)
1998 17K total front failure with out warning. Heads are in the shop right now.
Originally Posted by Moto Man
(Post 185653)
47.000 and still quiet.....but you guys have been making me nervous,
soooo----just got apes...shops want too much; have to put 'em in myself, I guess.... |
Gee NuHawk, thanks!
rant off.
Just relpaced mine at 49500 km (31000 miles) after failure of front one. Replaced with manual.
Previous owner replaced first set at 30000 km (18750 miles). Bike is a 2000 model. |
rant off.
Wow, that was just childish. Your caps lock...please fix it. |
I replaced mine as I was building the bike (02 with 14k) and they hadn't failed. The old ones are available if anyone wants them.
1998 with APE CCT's installed by previous owner at 18K. I think it was preventative maintenance.
So for your files, stock tensioners survived at least 18K. |
'98. happened just under 13k miles.
'98 never failed, installed APE CCT as preventive maintenance at 15K miles.
You have to put a couple things in perspective. First off, most of the Superhawks out there are 98's because that was its biggest sales year. IIRC it was about a quarter million bikes - next year it was about half that and at the end of its run the Superhawk sold 60-80K bikes per year. Age seems to be less a factor than style of riding. One of the members here had a 01 that went down at 16k. Members here that replace tensioners in the mid-teens come back to do chains at thirty k. Like has been said. Preventative maintenance is the presumptive edge that a Superhawk (and a vast number of other Honda vehicles) require to avoid catastrophic damage to the engine.
The second thing is that most of the guys that have had failures don't hang here anymore. Some rebuild but most don't. It ends a chapter and guys move to other bikes. The guys here that have done the maintenance still have our Superhawks. |
(Post 185728)
I know how you feel. I didn't have it happen to my Superhawk but it did happen to my Prelude. Cute little car that I dumped thousands into. I had no clue the valve train problems of the Honda bikes extended to their automobiles. When the timing belt gave out I crushed three of four cylinders.
2000 model: rear failed in my 13th month of ownership, which I believe was about 5k miles. I was able to get it slid in under warranty. Happened again (rear) about 8 mos later at about 7500 total miles. Had it warrantied again. Happened again roughly a year later at less than 10k total and I finally said screw factory ccts, completely tore it down and replaced the affected valves, seals, pistons (no damage, just wanted the JEs) and installed the Apes. No problems for 5 years. So I went through 3 on the rear in less than 10k, never a front. Maybe it is riding style, but I'm really not that hard on my bike, though there was that minor broken crank issue a couple years ago...
