Please help blinker wires
https://cimg8.ibsrv.net/gimg/www.sup...3727a9724a.jpgThe plug on the right of photo is my brake and running light and tag light plugged into integrated signal. I need to figure out which are blinker wires to plug into my new blinkers which are 2 wire only. I know no runnin light if 2 wire . Guy before me really fucked up the wiring. I just got my front blinkers to work
please help. I can't get more tickets |
Originally Posted by Mvanriel60
(Post 404269)
From what you posted I'm understanding that the tail light has integrated turns. Are the turn bulbs LED? If so, that is the source of the rapid blink. You'll need a new flasher relay designed for low resistance. A ~$12-15 part.
True about the bilnking but the rear signals were never running lights. Rear constant lights are red. Only signals are orange.
Originally Posted by xeris
(Post 404273)
Originally Posted by VTR1000F
(Post 404275)
This too will solve the problem. Just straight from the country of origin.
https://www.ebay.com/itm/Motorcycles...hWYPxL&vxp=mtr Or just go down to the auto parts store and get one there. |
I bought an inexpensive integrated blinker as well, came with two resistor blocks (I suppose to offset the blink rate). Not sure about the wiring either, haha.
Edit: Figured it out, no big deal.. https://www.superhawkforum.com/forum...l-light-21956/ |
I thought the VTR had a 3 wire relay?
Installed the LED integrated tail light from ebay. Great idea someone suggested using one (of the two), bulb connectors to power the brake light, and then just connecting the other two wires to each tail light wire, and not using the ground, as it's already grounded. Great suggestion, works perfect.
Here is a foto of which color wires on the 3 prong bulb, go to which wires on the LED integrated tail light, in case anyone hasn't done this mod.https://cimg3.ibsrv.net/gimg/www.sup...1f581447ad.jpg After testing it, I cut off the 3 prong, and soldered the wires to the tail light wires, and shrink wrapped 'em. |
Rear blinker wiring
So, if I am understanding this post, there are no running lights in the rear blinkers?
The wires that I have are Green, Orange, Light Blue. Orange for the left blinker Light Blue for the right blinker And the Green is common for both right and left. That is what my 1998 Honda Super hawk is wired? Does this sound right? |
Originally Posted by jimpapay@yahoo.com
(Post 406674)
