Picked up a screw with front tire...
Hi, getting home today I noticed a lil screw on my front tire. As I started to unscrew it with my fingers and praying I was able to take it off. I looked pretty long, about 1/4 inch maybe. I was expecting the tire to loose all the air but. It doesnt look like its loosing air at all. How safe it is to ride with a hole almost all the way thru? Tires are dunlop, they are in pretty good conditions. also, what size it recommended for rear. I think mine is too small. I got the bike a year ago tires were almost new then. thanks guys.
Put so soap & water on it and look for bubbles. No bubbles you should be good to go. The rear is a 180\55-17
Originally Posted by 8541Hawk
(Post 351161)
I also need to adjust the front suspension some how. I feel like they are set for a 100lb guy. Im 250 lol... |
Thumbs up for the 250 !
You guys make me feel better... I thought I was too big for the hawk at 215.
Originally Posted by archaicguy
(Post 351173)
But, then again, if you are north of 130-140 pounds or so, you are really to heavy for the stock front suspension... The paradox is that the rear works like crap for a lightweight, and decent if you are a heavyweight... |
Originally Posted by jonjonsocal
(Post 351162)
(Post 351185)
That's because they are... ;)
(Post 351194)
they are adjustable right?
(Post 351162)
Thanks man! Ill check in the morning.. theres so many things I want to do before new rubber I hope Im good..
I've ridden for thousands of miles after pulling sharp objects out of my tires. I did plug them though.
Until the new springs, add like an inch of heavy fork oil, it will make it worlds better. You can also add spacers to firm it up. |
(Post 351225)
(Post 351199)
Shoot me a PM so I don't miss any of your questions. Yeah there is very little you can do to the front end without springs and valves, which we can do also.
JON |
