Oil Filter
Does anybody have the link for the cross reference numbers for all the differnt oil filters that will fit the sh? I found on here where it is linked but when I click the link it just sends me to the main forums page..........
thanks! |
I don't because Honda filters are the only filters I use; why would you even consider anything else?
So you don't have to bend over without the lube!:evil:
Try the link again it just worked for me. I've been using the supertech 7317. https://www.superhawkforum.com/forum...ead.php?t=1930 |
I picked up a FRAM for mine from Wally World... I dont think type of filter is going to be very critical, changing them frequently will do just as good !!
Why not just stick with the MM9 filter? They are only about $5, so the most you are going to save is a couple of bucks. They are so good that the Kawasaki guys use them too.
Try the link again it just worked for me. I've been using the supertech 7317. https://www.superhawkforum.com/forum...ead.php?t=1930 BLAH!!! Lube!!! Blah ha....Supertech 7317 Rules....But I do hate giving my money to Wally world....Lube....LMAO.... |
If you ever forget, just remember that it matches the ones prescribed for a mid-90's Miata. I go with the supertechs, as I've seen testing results that place them in the top 1/3 for filtering, and they're CHEAP so you can do them more often w/o even blinking.
