Not getting Fuel from the tank.
Hey guys,
I have a 98 SH and recently I blew my motor so I picked up a new one and dropped it in. I figured i would take advantage of the down time and give it the pain job it was in desperate need of. My question is this: Is there a vent on the top of the tank i may have sealed while painting it? because we are getting it to run fine without the tank on the bike but once i hook everything up it just refuses to stay running. any help is greatly appreciated. Thanks, Nick |
Unblock the hole with a bit of wire (and blow through with air) that's just on the inside of fuel cap where you shove the nozzle as it sounds like you're getting vacuum lock.
Plus check the internal fuel filter inside the tank on the fuel tap. No 3 > http://www.ronayers.com/Fiche/TypeID...roup/FUEL_TANK But before all that make sure you have the vacuum hose connected correctly to the BACK of the fuel tap. and NOT the bottom. Just in case - have you fitted inline fuel filters to the fuel hoses? |
No extra filters the fuel lines are completely stock and I am certain I have them connected correctly me and a tech here looked at the service manual to be sure.
Pushing the wire through that hole... will that push what ever is blocking it into my tank therefore into my gas? so in theory I should do this then empty my tank, then put fresh gas in and try and get it running? I will be trying this in a little bit after I clock out. |
Originally Posted by ima98chickenhawk
(Post 340365)
Pushing the wire through that hole... will that push what ever is blocking it into my tank therefore into my gas? so in theory I should do this then empty my tank, then put fresh gas in and try and get it running? I will be trying this in a little bit after I clock out. When it was resprayed was the fuel cap area masked off? I am certain I have them connected correctly me and a tech here looked at the service manual to be sure. |
Originally Posted by Wicky
(Post 340366)
Shouldn't do as the path of that hole leads to the fuel overflow drain spiggot that's comes out at the bottom of the tank and connects to a drain hose that runs to the outlet nr. the the bellypan at the front.
When it was resprayed was the fuel cap area masked off? Best and easier to double check ;) This should remedy the problem... |
wow I'm an idiot. thanks for all the help dude. bike runs great now. just put the vacuum line on the wrong port for the fuel petcock.
ride safe gents. |
Another case of PVLIR
