Is this normal engine noise?
E: Solved. It was the primary drive damping gear.
Ok. Greetings from Finland.It's my first post here. I bought my VTR a couple of weeks ago and I've wondered a strange "knocking" noise when bike idles. Noise cannot be heard when driving but it's always there when bike idles. Even if it is cold or warm. I haven't had a chance to compare my bike to another. Idle noise VTR whining after repair |
Does it go away when you disengage the clutch?
Does it go away when you bring up the RPM's from idle? |
(Post 280266)
Forgot to mention, valves have been checked about 8000 miles ago. Everything was fine there. |
(Post 280266)
Sounds like CCT's (cam chain tensioners) to me. Do a search for more details.
I've read a lot about CCT:s and I've already ordered new tensioners. Maybe I'll check the valve clearances even though they should be checked. At least I've been told so.
If the noise is just at idle and low RPM it could be the carb slides opening and closing. They are rather large and do make a "hollow" clunking noise at low RPM which is just a normal SH noise.
If you have a stethoscope (or the old screwdriver handle trick) you can try to locate where the noise is coming from. But a CCT "should" make noise all the time. Changing the CCTs is a good thing though. Not so much because of all the paranoia caused by some of the threads here but because you really don't know how they were treated by the previous owner. Checking the valve clearance is also a good thing while your are in there and I always double check that on a new to me bike. You didn't say if you were installing auto or manual CCTs. IMHO either works fine. There are just a few "rules" if you run the auto (or stock) CCTs. 1) Don't let the bike sit and idle on the side stand. 2) Don't slam the throttle shut from high RPM. 3) Don't lug the motor, or try to keep it above 3k RPM in most situations. Have fun with your new bike. ;) |
The noise comes only when the bike runs idle. I tried to pinpoint the noise with a large screwdriver without significant results.
I bought stock CCT's, because I didn't find APE's in European Union on eBay. Finnish customs doubled the price of Factory Pro-made emulsion tubes to my previous GSF1200, so that's why I didn't buy APE's from USA. |
Make manual CCT's out of the stock one's instead... Much better and a lot cheaper...
Well, I'll try new ones first as they are already ordered.
Originally Posted by Torsti
(Post 280286)
New CCT's installed and valve cleareances checked. All OK, but the sound is still there. I think the next solution is louder pipes.
It was a bit difficult to align marks for front cylinder TDC pushing the bike on sixth gear. I found out that Honda had made front TDC aligning mark to rear cylinder camshafts. One crankshaft turn is half turn at camshaft. So 1 1/4 crankshaft turns, which is required to put front cylinder to TDC, is 5/8 turns at camshaft. Just put the little circle above R-I mark pointing left after you have set the rear cylinder to TDC. Much easier to look for that mark than looking the tiny F-mark on flywheel. Of course you have to look the R-T mark on flywheel when setting the rear cyl TDC. Hope you understood my meaning, since I'm not native english speaker. http://lh6.ggpht.com/_c9cUWl1pp_o/TI...0909213552.jpg http://lh3.ggpht.com/_c9cUWl1pp_o/TI...0909213633.jpg |
well if the cct's didn't do it, and you bought the bike just a couple weeks ago and didn't have the valves check 8000 miles ago yourself, that would be my next plan of action.
........ Carb Slides......... ;)
SOLVED!
It was the clutch. Noise goes away when clutch is disengaged in first gear. I did not notice this before because I tried to engage and disengage the clutch lever in neutral position.
Finally solved, thanks to www.superhawkforum.com
