No Start... need some help
so yesterday i installed my mototeck under tail, i never unplugged anything except for the very end of the wiring harness I/E Taillight turnsigs and plate light, so i finished it up and went to start the thing and it wont start, i turn the key everything comes on all my lights and stuff work and it cranks but wont fire, any ideas as to what it could be thanks in advance
Did you check the kill switch? I've been riding for years and still do that sometimes.
Originally Posted by drew_c14
(Post 220170)
bump... i really need any kind of insight i have no idea where to start
well have you checked all the fuses?
side stand or clutch switch?
check your hi beams. lol
fuses are good im not getting spark, actually im not getting any signal to the coil
Dude, the most important parts of your ignition system are right back by the taillight.
You probably unplugged a box. Did you make sparks when you were playing with the wires back there? If you did, you could have shorted and faulted your ignitor. |
no nothing is unplugged and no sparks at least from what i saw the only thing i did differently is move the ballast box for my hid from the center of the tail section (surrounded by plastic) to against the frame rail in the back and i turned it on before i tried to start it i dunno id the box would have short circuited something
well i fixed it.... i clipped some wires going to the one ignition box with a drill bit like a retard... all in a days work..... sometimes i want just one thing to go right
Glad you figured it out! Gotta watch where them drill bits go..
At least you didn't do this: http://www.zxforums.com/forums/zx-6r...need-help.html |
wow yea i'm not that dumb thanks everyone for your suggestions
Zilla Out |
i did the kill-switch dummy move yesterday
I was gassing it up at the station near work and spilled gas all over the bike. I figured I flooded the carbs because after I wiped it down it wouldn't start. I never touch the kill switch even though I ride 50 miles a day rain or shine. I posted on CraigsList motorcycle forum "how long should I wait.. don't want to run my battery out trying but also don't want to be here all night", and within 10 minutes someone told me to check my kill switch. DOH! Going to start using it now just to keep this kind of stupidity from happening again.
Originally Posted by Billzilla15
(Post 220249)
