No break light.
So after messing around with the SH, i noticed there wasn't a break light (flash) when i apply either breaks. The regular daytime running light works just fine, just not break flash. I just noticed it today, not sure how long its been like that. Checked wire connections and i cant seem to find a loose wire. Any ideas?
Don't you hate it when you break your brake light........
Check the fuse box. :thumbsup: |
:shock: lol
Also, check the switches att handle and foot control... They are prone to breaking...
I had the the same issue once, if both of the bulbs are ok, it may that the the brake lights are on all the time. My rear brake switch needed adjustment.
i just thought about that today. i wonder if its just the break lights are coming on, ORRRRR, they are on all the time cause the tail light is always lit when the bike it turned on.
