neutral oddness
Ok, if anyone knows what this is then ...
Anyway the behaviour is this: Neutral light functions normally until engine warms up to normal operating temp, then as the motor warms up, the light begins to flicker a bit while in neutral then when the it's very warm, the light will not light up at all. Cool off the engine, it works fine. Way weird :o Jim |
Hello all,
I'm reviving this old thread because I am having the same problem. Perhaps in the intervening four years someone might now have an answer? Thanks in advance. |
Originally Posted by nekkid
(Post 225220)
Hello all,
I'm reviving this old thread because I am having the same problem. Perhaps in the intervening four years someone might now have an answer? Thanks in advance. we would go out to see the ladies on friday end up at the spot and when we jumped in to leave sometimes/alot of times the car would not start till it had cooled for a while. this problem was the most perplexing and annoying. it stumped many a mechanic. most thought it was over heating but it was not. it was just a shitty .12 cent back yard mechanic quick fix that drive people insane trying to find it. So in the interest of not going insane, check all your wiring. look for cracks, after market splice ins. It sounds like a resistance problem to me. |
Make sure you have a good connection on the switch/sender mounted in the engine case. It may be dirty or corroded.
Sounds like a bad neutral switch or loose connection to the same. See page 19-22 of the service manual. Easy fix and the part is $12 through Ronayers: http://www.ronayers.com/browseparts....e.ronayers.com
Thank you 5150, shayne, and Hawkrider. I will check out the bike over the long weekend and hopefully this will end my pesky problem.
(Post 225333)
Sorry for the long wait before replying to you. My bike has been in the shop for the past 2+ months. This local repair shop is known for taking a their sweet time. Just got the bike back and the neutral light problem is still there. I will probably have to tackle this myself. Also, the bike used to run as smooth as glass between 4 and 5 thousand RPM. Now there is an additional buzz or rumble I can hear and also feel through the handlebars.
