Need a pic or pin out of a TPS harness
I am currently reworking my bike, and the PO screwed up the TPS harness on the carbs. The lock tabs in the connector are loose, and the wires pulled out of the connector. There is conflicting information in my service manual regarding this connector pin out, and I need to know the order of the wires in relation to the connector to put it back together. Any help would be appreciated!
Thanks! |
Wires go Green, Red, Yellow from top to bottom on mine
Thanks bud! I found a picture of a harness on ebay and that is how it was wired as well. Its what I'm going with then.
I won't find out for awhile if it works...I am in the middle of building an alloy tank and stripping the bike more, so everything is apart right now. I appreciate the response! |
| All times are GMT -7. The time now is 05:05 AM. |
