NEED: petcock or rebuild for one. and Choke needle.
took petcock apart and diaphram was ripped. when i took it of the filter in tank fell apart.
So i need filter and diaphram... took carb apart for cleaning. BIKE SAT for 2 years. the slide diapram was melted to the side.... took choke cable out, the needle stayed in carb. by the time i got it removed it was damaged. Also could use bowl gaskets. ANYONE CAN H E L P? or point in direction. other then bikebandit.com.... |
There is some rebuild kits on ebay,those are your best bet.
Ronayers.com is a good site to go to.good prices. You might find filter and new O-ring for petcock on ebay,but most likely not. Amazon.com is a good source too.I got a lot of stuff at great prices. |
I have a petcock rebuild kit that i never used. Let me know if you want it.
Yeah, ronayers has the fiche so you can find the parts and good go-to place.
Most of what you are mentioning are cheap, small and really you dont want them used since they would be on the brink of failure anyway. |
mp sent to jay956 about P-Cock rebuild kit.
petcock rebuild kit
still cant find an in-tank filter and choke needle. pleasee help :confused:
unfortunately they don't have anything i need in this instance. i don't need an air filter or jet kit... But thank you for your time never the less.
Originally Posted by RWhisen
(Post 327581)
Originally Posted by trickedoutz
(Post 327583)
Ronayers.com Microfiche Honda>Motorcycle>2002>VTR1000F Shop away! |
number 3 is for the filter you want.
Ronayers.com Microfiche Honda>Motorcycle>2002>VTR1000F>FUEL TANK number 11 for the needles that go at the end of choke cable into carbs,need 2 sets if doing both ends. Ronayers.com Microfiche Honda>Motorcycle>2002>VTR1000F>CARBURETOR COMPONENT PARTS |
thanks.
