SuperHawk Forum
-   -   NEED help with wiring! (https://www.superhawkforum.com/forums/technical-discussion-28/need-help-wiring-29889/)
sneeze Feb 23, 2013 06:09 PM
so im in the gritty part of my street fighter build. ihave everthing apart ready to rock! As I am test wiring the bike back togther i have come across the issue that in order to eliminate my guages i need to some how bypass the guages but still have my tail light and other things that are on the same circuit..i intend to later on have upright bars and then install a small aftermarket gauge set up but for now i really want to ride kickin it old school. figure wind blast means im going to fast .. good enough .. So cal cops dont care as long as yer around 85 or less:cool: please HElp! my v8 audi will empty my wallet in days commuting...
RWhisen Feb 23, 2013 06:43 PM
You won't get that much better mileage on a Superhawk!!
Navigate to Tweety's page and open the wiring diagram:
Tweety's Wild Thinking
sneeze Feb 23, 2013 06:58 PM
thanks forgot to mention mine is a 03.... his diagrams are for a 97--2000.. thanks for the reply though..
Jack Flash Feb 24, 2013 08:14 AM
https://www.superhawkforum.com/forum...-manual-11365/
'01 to '05 wiring diagram is at the end....
Tailhooker Feb 24, 2013 11:49 PM
Where does it go
When I got my hawknback from valve adjustment I found an unconnected connector. On page 50 fuel it is circled cannon type plug where does it go? Everything seems to be working
Tweety Feb 25, 2013 04:29 AM
The only differences to the newer bikes are the connector at the gauges being a single one, instead of two... Other than that they are 100% identical... And since wire colors match, it's not hard to "translate"...
cybercarl Feb 26, 2013 09:09 AM
It would be easier to identify if you posed a pic.https://www.superhawkforum.com/forum...ons/icon14.gif
[edit]ignore that I just seen the other thread{/edit]
