SuperHawk Forum
-   -   My Superhawk makes a "whining" sound (https://www.superhawkforum.com/forums/technical-discussion-28/my-superhawk-makes-whining-sound-11552/)
BMDailey May 24, 2007 07:41 PM
Hello. My Superhawk makes a whining sound. The sound seems to be coming from the engine area. Any info would be greatly appreciated. My bike has sounded like this for a year, and if there is something I can do, I would like to do it. Thanks
Hawkrider May 24, 2007 10:00 PM
Which side of the motor? Based on engine speed or road speed? High or low rpm? Please provide more info. A sound clip wouldn't be a bad idea either if you have the resources.
nineighthawk May 24, 2007 10:21 PM
More than likely it's the cam chain. Mine whines pretty good.
It has for the last 15k miles.
Hawkrider May 24, 2007 10:35 PM
It shouldn't whine. I think if it whines then it may be too tight. You have APE's or stock?
mkimber May 25, 2007 05:19 AM
Mine whines also. It sounds exactly like a supercharger to me and everyone else. It is most noticable at idle and low revs. The bike has 5K miles and the stock tensioners.
falcondrvr May 25, 2007 05:27 AM
mine makes this noise as well and has for as long as i've had it (from 8000-13000 mi). somebody on here once suggested that it sounded like a Jetson's mobile and i think that's pretty accurate. to me it seems normal. i've got stock CCTs.
Sgt Rock May 25, 2007 05:38 AM
That's interesting because mine has had the same whine you mentioned for over two years now.
Cleveland May 25, 2007 09:07 AM
Mine also. Bought bike last April 06 had 6000 miles on it, now has 15000 on it. Made the sound from the day I got it. I just assumed it was the water pump impeller, or just a characteristic of the engine. I heard a TL got by my shop the other day, and it made the same sound only LOUDER. May have been due to stck pipes on the TL.. I cant hear dick over my pipes... (shortened Erions by half)
swordfish May 25, 2007 10:36 AM
I think we've established that this is a normal sound. the explanation I got from a guy at my local shop was that all V-twins with overhead cams make the noise to some degree. its the price we pay for not having to adjust the valves until the 18,000mile mark. ducs are gear actuated, so they don't whine, but they need more frequent maintenance. pushrods, same thing, but overhead cam engines can rev way higher than pushrod(harley). just gotta learn to live with it. RC51, TL1000, KTM superduke, they all whine.
Babelfish May 25, 2007 12:14 PM
Ducati is very far from gear driven, they are belt driven.
swordfish May 25, 2007 11:08 PM
belt "driven" yes, but aren't the valves gear actuated?
BiggDaddyKool May 26, 2007 12:46 AM
my (new to me) 4300 mile engine has the same whine.
Babelfish May 26, 2007 04:56 AM
No the cams are belt driven and the valves are actuated by a adjustable fork that push or pull the valve. Much like a gear selector fork, but adjsutable gap.
Birdoprey May 27, 2007 07:54 AM
I thought it was the primary drive. lots of bikes do it, Hondas maybe moreso.
swordfish May 29, 2007 11:53 AM
well I guess I stand corrected. are the 4 valvers set up different? I could have sworn that I heard ducati's have gear actuated valves.
Hawkrider May 29, 2007 10:19 PM
The old bevel drive Ducks had them. I think they're all belt driven now.
This is a bevel drive: http://twistingasphalt.com/index.php...engine-cutaway
This is the modern 1098 motor: http://www.ducati.com/en/bikes/my200...del=SBK1098-07 Click on ENGINE.
Babelfish May 30, 2007 07:57 AM
1 Attachment(s)
And here's the desmo system used on all their bikes nowdays.
I was a bit confused in the beiginning whan I saw this drawing as it use a return rocker arm spring but it's not used to actually lift the valve, but only to apply a light pressure when closed. Therefore a much lighter spring than on conventional DOHC machines.
