Moriwaki full race exhaust: Help with this dang thing!
Anyone on here have a Moriwaki full race exhaust? I'd like to ask a question or two. Thanks.
I don't have one but I do have an Indigo full system that might be similar. What kind of problem are you having? Maybe if you describe it we could help you out.
Re: Moriwaki full race exhaust: Help with this dang thing!
I have one. Titanium headers and carbon mufflers. I have only just purchased it second hand and it is sitting in a box in my garage.
What do you want to know? |
The mid-pipe on the right side is a bit longer than on the left; I've left the nuts a little loose on the headers so that I can move the joints around and see what works best, but still too long. Do you happen to have any litterature you could scan and send via email Shayne?
Sorry, no instructions.
I have gone and had a look at mine, and I cannot see any room for adjustment. You mention a "mid pipe" which I assume to be the pipe between the muffler and the collector. On my system these pipes are integral to the muffler, and are of equal length on each side, although of a different shape of course. Is it possible that the muffler mount is at fault? Do the mufflers end at the same position at the rear of the bike? No other ideas I am afraid. If all the joints are fitted together properly, then that only leaves some production error to be the fault. |
I have the Moriwaki full system. I'm not sure what the problem is that you are describing. Can you assemble the full header forward of where the aft pipes and canisters go on?
