Missing vacum line
Hello to all I am new here, anyone knows where this line comes from or goes to?
Thanks to all, I recently got this bike and I just clean the carbs, today I got the plugs so hopefully today runs. |
one will be from the rear cylinder to the petcock
probably need a bit more info though |
Sorry guys I am new here :/
If that line is on the front cylinder, then it gets capped off and used for syncing the carbs whenever you get done with carb work. If it's on the rear cylinder, then you need a vacuum line running from that nipple to your petcock.
Thank you CruxGNZ
Make sure you put the vacuum line on the right nipple of the petcock, otherwise your bike won't run correctly.
Chris, that vacuum line does not go to the carbs, it goes to the petcock. For pictures that show vacuum line routing to the petcock, you should re-read the thread you actually posted in. I linked to it below.
https://www.superhawkforum.com/forum...ix-pics-19843/ Also, you cannot link pictures to dropbox as far as I know, so that's why your pictures will not show up here. You need to upload your pictures to a site like Photobucket or the likes. Also, if you haven't yet, you can download the Superhawk service manual for free. All you need to do is look in the Knowledge Base here. I would strongly recomend doing this. |
Big thank you :)
