LED Flash Controller
Just bought a flash controller (3 pin variety) on Ebay to reduce the flash rate of my aftermarket turn signals. It's arrived, but with no instructions - if anyone knows where it plugs in I'd be grateful!
1 Attachment(s)
Picture of the control unit, in case it helps
It most likely replaces your stock flasher. Its under the plastic on the right side, next to the RR
thanks
It looks to me like the pins are different than the harness, so it probably won't plug in directly. How's your wiring skills?
thats not going to work thats a unit for a car you need a motorcycle one like thishttp://www.customdynamics.com/trick_...rd_DOT_Flasher
just plug it in and you're done i have it on my bike and it works great |
Originally Posted by Gregw
(Post 243432)
On another note - the clear alternatives integrated LED tail light is a very poor thing. Turn signals are very hard to see (especially in daylight - nigh on invisible) and the light itself is none too bright; I had it on the bike less than 6 weeks and have put the stock one back on. |
Originally Posted by Onsto
(Post 243456)
| All times are GMT -7. The time now is 12:55 AM. |
