K&N Filter Block-offs 1 missing?
Does anyone know what the rubber block-offs do that are in the airbox? I decided to change the filter for the first time and found that there is a K&N filter but one of the rubber block-offs is missing. It looks like air can bypass the filter through these holes. The rubber tube to the carb is a vacuum line or smog crap? I don't know what the original set-up looks like since the bike came with a K&N. Any help would be appreciated. Thanks.
Originally Posted by Montana
(Post 161121)
Why block-offs?
Why are they blocked off with the K&N and the stock set-up uses foam?
(Post 161128)
THANKS.
Thanks. I will have to find a rubber block off.
| All times are GMT -7. The time now is 04:20 AM. |
