Jet Crossover Table
I thought someone posted a crossover table awhile back. Using the "search" for about 45 minutes and could not find it. I am interested in finding the equivalent Keihin jet sizes for Factory sizes. Could someone repost or send me the link?
Thanks, SW |
I posted one a while back (but have since run across a few and there seems to be little consensus as to the actual relation....) Keihin and Factory use the same numbers (it`s DJ that differs).
Search"dynojet het kit,drilling"
Originally Posted by mikstr
(Post 255982)
I found your earlier thread. What I didn't get out of it was that Factory jets use the same numbering and are probably rebadged Keihin jets. The PO had 182 & 185 Factory jets with a K&N & no other mods. Three sizes for just the K&N, seems a lot! Thanks, SW |
Originally Posted by Hawkagain
(Post 256012)
You can change the exhaust and often not need to rejet, but even if you have a stock exhaust and you swap to a K&N you will almost always have to rejet. |
