Intermittent idle stall on a newer hawk
Old Sep 3, 2006 | 12:27 PM
2005Hawk2006's Avatar
2005Hawk2006 is on a distinguished road
Question Intermittent idle stall on a newer hawk
New to the forum, this is a great site, kudos to all the participants.
I just bought a brand new 2005 Hawk a couple of months ago. I had an F3 before, so the V-twin is new to me. I love the way it sounds and especially the low end torque on it .
My hawk has 1100 miles on it now. I am having a problem when it is idling. It seems to hickup, basically starts to stall or stalls. It always starts right back up if it requires it. But it does happen again. I have adjusted the idle speed with the screw on the right side to to the upper range of the factory recommended idle speed, this helped but stalling or hickuping will still occur.
The dealer I bought it from is two hours away, so taking it back for warranty servicing is very inconvienent. A local honda dealer said the hawk probablly was not prepped correctly and the carbs need to be cleaned. I am waiting on a call back form the dealer I purchased it from. Does anyone have any advice for anything I can do techinically or to get correct service from the dealer? I also read a post about lubricating the carb slide, but that seemed to apply to hawks with more miles.
Thanks,
Brad
Old Sep 3, 2006 | 01:39 PM
nineighthawk's Avatar
nineighthawk
Most SH's do that from time to time. I cured mine by putting an extended runner on the fwd. carb.
Alot of the time, putting on a K&N will cause the "clunk die" scenerio.
Try increasing the idle to 13 - 1500. Just turn the Idle adjusting **** in 1/2 or 3/4 turn. That might help.
Old Sep 3, 2006 | 01:40 PM
nineighthawk
Oh, and welcome to the forum.
Old Sep 3, 2006 | 02:25 PM
You need a good carb sync and adjust the idle mixture screws to 1.75-2.0 turns out. Raising the idle will only hide the symptoms, not cure the cause.
Old Sep 4, 2006 | 12:45 PM
I have an online Honda service manual that I downloaded. From what I have read a carb sync seems quite simple, but where is the place to get the pressure guages for the reading of the lines. Also where is the place to get a specialty tool for the idle mixture screw. I have an '05 so I would assume that I have the special shaped screw head?
Thanks Greg
Old Sep 4, 2006 | 04:05 PM
Nanotech's Avatar
Nanotech is on a distinguished road
I have an '05 as well and just clicked past 3200 mi....it has been "hickuping" for the last 1000 mi for me also. Not always, but occasionally at stoplights and only when idling. Mine is set at 1400 rpm idle, and runs perfectly, but it is annoying to hear the hickup even if it isn't affecting performance.
Old Sep 4, 2006 | 04:06 PM
Nanotech's Avatar
hiccup...just looked kinda funny the other way and was bothering me
Old Sep 4, 2006 | 09:24 PM
A Team's Avatar
A Team
I have an 05 with 3300 miles on it. I only notice the problem when I put cheap gas in it. When I fill up (87 octane) at cheveron or 76 it seems fine. However, when I go to the no name gas stations it will pop and die every once and awhile.
It works for me.
Old Sep 5, 2006 | 01:51 AM
I wish that was it - I only put in 93 Octane. And I know never to fill up when the tanker is putting gas in the underground tanks becasue it stirs up the setiment.
Old Sep 5, 2006 | 05:58 AM
hawxter996's Avatar
ole dirty bastard
hello greg that is what i found with mine.
simply backing the idle mixture screws out slightly cured my stalling probs.
Old Sep 5, 2006 | 09:04 AM
I've no idea where to get the mixture screw tool, other than the $125 that Honda has, but then you don't need to remove the carbs to use that one. You could always go by the dealer with a box of Dunkin Donuts and get in good with the service guys there. That's what I did. Factory Pro has them in their jet kits. You might contact them to see if they sell separately.
Old Sep 6, 2006 | 11:24 AM
Thanks fellas for your help!
Brad
Old Sep 14, 2006 | 06:52 PM
senecagreen's Avatar
senecagreen
adjusting the idle mixture screws cured my 05.
Old Sep 14, 2006 | 08:45 PM
See, I wouldn't lie to ya'! Always here to help my fellow 'Hawkers.
Old Sep 14, 2006 | 11:59 PM
SillyHawk's Avatar
SillyHawk is an unknown quantity at this point
No Dunkin Donuts out here...sob sob
wannabridin
Oct 25, 2014 10:51 AM
digfig
Jun 12, 2012 06:10 AM
JRip
Aug 24, 2011 06:20 AM
imp
Oct 18, 2009 05:15 PM
kroeninga
Sep 13, 2008 06:52 AM
