SuperHawk Forum
-   -   Interchangeable engine years? (https://www.superhawkforum.com/forums/technical-discussion-28/interchangeable-engine-years-36152/)
Rideitlikeyoustoleit Dec 28, 2023 11:39 AM
Hello,
I'm new to the Superhawk world. I've recently acquired a '98 Superhawk and needing to swap out a engine. I've tried to do some digging on this but not had much luck. What years of the Superhawk engines will interchange with each other? Will all the years fit 98'-05'? Thanks!!
xeris Dec 28, 2023 05:03 PM
All years are interchangeable.
Be careful as there many motors that have had a cam chain tensioner fail. Most of the time they are fixable, but heads, if it needs replacing, especially the front are getting scarce.
Rideitlikeyoustoleit Dec 29, 2023 05:26 PM
Ok thanks for the heads up, I really appreciate it. I'll took into some manual adjusters as well!!
fabiostar Jan 7, 2024 09:03 AM
as above they all fit but cct fail on the fronts kill a lot of them, the good thing is a rear head can be made to fit and they are cheap to find and easy to fit
