Indicator help needed urgently
Hi
I replaced my indicators with smaller ones, one front one isnt working all the other 3 are. what could be wrong? where does the wire that comes out of the indicator go? maybe i yanked its other end out when i was trying to pull enough out to strip and get enough to put a connecter on?? anyway, my m.o.t inspection is tomorrow at noon lol i need help fast all replies appreciated |
Well, you didn't say if they are LED's or not... If so the polarity on the two wires matter... If they are LED's try switching them around...
If not use a multimeter to check if it's been damaged... But that's highly unlikely as it's several foots of wire wrapped in tape and bunched with other wire's in a large harness... It takes a lot to move it... And a lot to rip it off... I highly doubt you are strong enough to do that by accident without knowing you broke something... BTW, general rule of thumb... Pulling on wiring like that is a dumb idea to begin with, it usualy ends up tight somewhere and chafed off... If it's too short, splice it... |
I think Tweet covered it.
