I think conrod is broken....
Yesterday I got a flat rear tire. After fixing it I decided to go for a spin to warm up the tire. I didnt make it around the block. It felt weir at first but i though it was me because I been driving my buddys 08 R6 the whole day. So after a few feet a clicking noise came out of the engine then it got louder lost power and the bike shutted off. Just like that in jus a couple hundred feet. I tried starting it and it sounded like if I was hammering the engine. So I left it. Didnt want to cause more damage.. I know nothing about engines but for what I read it sound like a broken conrod. :-( Im really sad bike has 14k miles it run and looks new. Never ben down. The previous owner baby it. I did too. So bummed. I dont know any good bike shops around here. Im not sure if I could afford dealers prices either.. So im stuck.
Check that the CCT has broken (more than likely front) - Don't try and restart it
Send me a PM and we can set up sometime next week so I can come and look at it for you, if you want. ;)
^^ take 'Hawk up on this. He'll be able to work on the VTR better than any mechanic in your area.
99% sure it's your CCT that failed like Wickey said. You have bent valves and maybe piston damage. ;) |
Originally Posted by Wicky
(Post 351290)
I do have the manual CCT. Could it still be it? What are the symptoms of it going bad? Thanks for your help. Brother-in law knows a motorcycle shop down in TJ, he said he can take it there and get it. He takes his bikes there all the time.. |
Originally Posted by jonjonsocal
(Post 351320)
I do have themanual CCT. Could it still be it? What are the symptoms of it going bad? Thanksfor your help. Brother-in law knows a motorcycle shop down in TJ, he said hecan take it there and get it. He takes his bikes there all the time..
The only manual CCT I have seen "gobad" was a homemade MOD done to the OEM ACCT.. It was a hack job to beginwith. The install of a CCT has gone wrong, or failed later due to fasteners loosening.or the CCT incorrectly set up.. The “WAG” methodof diagnosis is hardly effective, normally costly, and usually less then satisfyingas tails are chased and money wasted. Issues like you describe are easily diagnosed withsome common sense and basic understanding plus mechanical ability. Any shopworth it’s name and a Sign out front should be able to diagnose a hard partfailure like you describe. |
If you have a manual CCT installed it is very unlikely to have gone the way that the OEM CCTS goes, However if it was incorrectly set-up or the tensioner bolt has backed out despite the locknut then it could cause interesting engine noises as valves meet piston. i.e sounding like a big bag of nails in a tumble drier.
The only way to check is to get in there and dirty by taking off the cam covers and seeing what's going on. |
Originally Posted by 8541Hawk
(Post 351291)
Not too sure yet about what the mechanic did to get bike up an running again, all I know is that replaced the valves. Bike should be here before I get home from work. Bother-in-law is picking it up for me. If the valves got replaced what should I expect? would the bike we and ride the same?
It wasnt the cam chain. The problem is that I dont really let the bike warm up before riding. Neighbors dont like me much. but after this Im going to piss the neighbors everyday I dont really care about what they think at this point. Thanks |
(Post 353141)
(Post 353144)
The bike doesn't need to be warmed up before riding... If the mechanic told you that, go somewhere else the enxt time...
"all I know is that replaced the valves"
Puzzled? If you have manual tensioners fitted then you need to know what went wrong and what's been done to stop the valves meeting the piston again. |
(Post 353149)
Get the money back from the 'Pro' you paid...
I got the manual tensioners they got installed a few years ago by a pro. my main question is if theres anything I should or shouldnt do after replacing the valves |
(Post 353153)
Yeah. Ill find out today when I get it. I got the manual tensioners they got installed a few years ago by a pro. my main question is if theres anything I should or shouldnt do after replacing the valves. Is there a breaking period or anything like that. Im kind of new to bikes engines. Thanks
What should you do after you replace the valves? Most people do a leak down test to insure the valves are closing. |
(Post 353153)
What ever you do do not fire it up and let it idle on the side stand! If you have a rear stand use it or just sit on the bike and let it idle up to temp. If all appears/sounds good ride it a few miles. I agree that a leakdown would be good but that doesn't seem to be something you have the equipment to do. |
Originally Posted by HRCA#1
(Post 353158)
Assuming that the problem was just bent valves there really isn't a breakin procedure other than making sure it's got oil in the crankcase. I would also recommend cranking it over with the kill switch off for @ 30 seconds to pump oil through the passages. If you hear any noises DO NOT START IT!
What ever you do do not fire it up and let it idle on the side stand! If you have a rear stand use it or just sit on the bike and let it idle up to temp. If all appears/sounds good ride it a few miles. I agree that a leakdown would be good but that doesn't seem to be something you have the equipment to do. @Wicky-- Prev. owner got the manual CCT installed. I didnt do any adjustments and I think I could hear it loose too. I was planing on getting it serviced right before this happened. I was going to take it to 8541Hawk. the guy that installed the manual CCT retired and moved last year he had 35+ years working for honda. thanks. |
The bike doesn't like to idle on the side stand, it mostly affects the auto adjusters but it can cause oiling problems. If you don't have a rear stand get one. Cycle Gear has them for $50 on sale! Otherwise sit on it start it up when you can take the choke off take off you're warmed up enough!
If you're gonna see Hawk he'll set you straight hope you like tough love..lol. As far as leakdown, most mechanics these days are too lazy to do it after a repair. They will offer to do it to sell you a repair though and charge you for it! |
Nothing but bad news guys... I want to cry. Bike started fine. But a noticed a lil knocking sound from engine. So turn it off. Then i noticed dents all over the tank. They dropped the gas tank and did a 1/2 a$$ job. Im tacking tomorrow iff just to go choke his a$$. I called the owner and he didnt know my vike was ready. The tech rushed his a$$ fixing it.....
(Post 353177)
(Post 353185)
(Post 353193)
I think it would have been a better idea to talk to hawn in the first place... Just sayin... *Shrug*
