I belive another cct issue
Old Jan 30, 2011 | 05:02 PM
Lilbitz909's Avatar
Lilbitz909
while riding I heard a real loud clicking sound coming from the motor. I was trying to put my head down while listening to the motor so i could find out where it was coming from. As i let off the gas it got alot louder and as i gave it gas it got quite. So i pulled over and killed the bike so i could inspect the motor. Couldnt find anything so i tried to start it and the motor was locked up. Would not turn over at all.
How can i determine which CCT Broke? And figure out what else broke with it. So far i have taken the front fairings off, gas tank, air box, and carbs. Im really new about doing any motor work with this bike. But i just paid a guy a couple of years ago to replace the cct and it cost alot. So i want to do all the work myself. so i can save some money. Almost to the point now where the bikes not worth fixing.
And one more thing. Im having trouble finding the Timing hole nut.
Old Jan 30, 2011 | 05:42 PM
Oh, really?
Old Jan 30, 2011 | 10:24 PM
slabm7's Avatar
The timing hole nut is on the left (clutch) side of the bike, on the lower side of the engine you will see 2 black removeable plugs. They are both threaded in. The one closer to the front of the bike is the timing hole. To see if you have engine damage you are going to have to pull the heads and have a look, its the only way to be sure.
Old Jan 30, 2011 | 10:38 PM
justinity's Avatar
Über Member
Sorry to hear that man.. I hope it was not the CCT.. Try not to turn it over if it might do more damage..
service manual http://www.haymouth.co.uk/phpBB3/vie...=18025#p145453
Good luck!
Old Jan 31, 2011 | 03:58 AM
JamieDaugherty's Avatar
Yeah, that's a real bummer. It sure sounds like the CCT's. Let us know what you find out.
Old Jan 31, 2011 | 04:15 AM
Gaggenau's Avatar
Gaggenau is on a distinguished road
More than likely its the front one (both of mine have), if you take off the little nut on top of the CCT and put a flat blade screwdriver in it and twist it (which wat i cant remember but i think its clockwise) you should feel a little resistance (if the front cct is ok), if the spring is knackered in it then you shouldnt feel any resistance when you turn the screwdriver.
Repeat for the rear one if the front one feels a little resitance, there will be a little oil drop out but it wont be a lot and it will stop.
Next step is to order some APE's lol
Install the till finger tight then back off 1/4 turn and lock off (remove the spark plugs)and hand turn the motor anti clockwise, if you feel it stop do not turn it any more as the timing will more than likely be out.
Renderw
Oct 2, 2012 04:52 PM
Superclean09
Oct 8, 2009 07:28 PM
minispeed
Jul 10, 2009 06:03 PM
radbikers
Feb 23, 2008 05:02 PM
junocdx
Jan 9, 2008 06:09 AM
