SuperHawk Forum
-   -   How much oil? What are the service intervals? 98 Hawk (https://www.superhawkforum.com/forums/technical-discussion-28/how-much-oil-what-service-intervals-98-hawk-7058/)
reelectreagan May 7, 2005 11:51 PM
I just bought a 98 hawk and it didnt come with the users manual. How much oil do you put in with and without the filter change? What are the other service intervals? Any other information I should know?
superbikemike May 8, 2005 07:12 AM
Re: How much oil? What are the service intervals? 98 Hawk
3.7litres w/o filter, 3.9litres w filter, 4.5litres after disassembly. Manual says oil and filter every 8000 miles but I do every 3000 miles.
Birdoprey May 8, 2005 07:32 PM
that's 4.2 U.S. quarts. I run 2000 or so on Honda non-synthetic oil. gods only know how long you can go on synthetic.
valve adjustments recommended at 16,000 miles.
what's everybody's thoughts on that? I've only got 4700 on mine.
99Hawk May 13, 2005 09:07 AM
With only 4700m I wouldn't worry about it, I did mine at 13K and everything was in spec, only one shim size off the median of the range so I changed mine one size on 6 out of 8 while I had it apart.
