How accurate is the stock tach?
I'm reading reports of the speedo being out by 10%, so i'm going to check mine with my Garmin Zumo 550 gps unit.
Makes me wonder about the stock tachometer. Anyone compared it to a dyno or aftermarket tach? How (bad?) is it? Let me know. PATIA! |
tach is usually dead on... speedos are what u need to worry about.
They are usually a few hundred rpm off at the top if you base it on readings from the dyno. Even my 1000RR is off if compared to the Power Commander software.
