SuperHawk Forum
-   -   Highbeam and kickstand light. (https://www.superhawkforum.com/forums/technical-discussion-28/highbeam-kickstand-light-10962/)
Blurr Apr 1, 2007 12:20 PM
I bought my Hawk used and ever since I had it the highbeam and kickstand lights dont work. I mean the highbeam lights one thing but the S light yeah kinda kicks me in the ass since I forgot it down a few times. Anyone know if its a bulb thing and can be replaced, or am I missing something.
marmaladedad Apr 1, 2007 03:42 PM
Is it the bulb itself that is out, or is the kickstand switch somehow loose/disconnected?
Blurr Apr 1, 2007 04:19 PM
Not sure theres no lights on, and yeah not sure where the switch is
marmaladedad Apr 1, 2007 05:17 PM
I'd check the switch near the kickstand first, before pulling the gauge cluster apart.
YellowHawk Apr 2, 2007 09:12 AM
Probably the cluster light, if the kickstand switch was disconnected, I don't think it would run...as far as my head thinks....
marmaladedad Apr 2, 2007 10:17 AM
That's something I had considered, but my kickstand sensor was disconnected once and I could still start the bike up with no difficulty. I didn't know it was loose until a friend riding behind pointed it out.
Blurr Apr 2, 2007 06:43 PM
Where is the kickstand switch? How do you change bulbs in the dash?
marmaladedad Apr 2, 2007 09:06 PM
The kickstand switch I'm referring to is next to the kickstand, on the other side ("behind" it).
shayne Apr 5, 2007 01:40 AM
The stand switch is a tricky sucka. I removed mine, and in order to have the bike run I had to bridge the circuit ie: if you simply disconnect the plug the bike won't run.
On my bike the plug is in the main loom above the battery box. It is the green plug with 3 wires in it.
Hope this helps.
Blurr Apr 5, 2007 11:49 PM
Yeah I dunno what it is but my light dont work the S light never cames on seem to forget its down not sure what else I can do, the highbeam light is another thing, maybe bulb in the dash burnt out
xecutech Apr 6, 2007 02:42 AM
I have an o4, but have never seen this light. Was this on earlier models or am I missing something?
