High beam dash light?
How hard is it to replace the high beam dash light? Mine went out this weekend.
Takes longer than opening a cold one... Shorter than drinking it...:)
Unbolt the dash and turn it over... unplug bulb and replace... And put it back together... |
(Post 194500)
Just reach behind the instrument cluster and pull out the rubber socket. Simple as that. ;)
(Post 194523)
The side stand warning light is hard to reach for sure... but the high beam light is pretty low and easily accessible.
kewl, I will do that today.
Suggestion.....if you are takeing the time to replace a bulb or 2 in your cluster because it burnt out.......replace'm all. If one went, otherss will follow soon. Just my .02
Fish |
Well I did that one in like 2 seconds with no tools since I had one bulb lying around the garage.. I'll have to buy more just in case I guess.
