HELP - Hawk Died on Hiway
Ok
Have new R/R & battery installed last year, about 5k ago. Anyway, riding home today, while lane splitting ;) VTR just died. iTs an '02 Pulled over - hit starter - bike cranked, but would not start :( Luckily a friend lives about 20 mins away - came & trailered to his place, we started checking stuff. Pulled spark plugs & front had none & rear very little. Then heard a whining noise w/ ignition on @ rear of bike. Behind R/R is a silver controller (ignition ICU ?) anyway it was making noise - a whine, squeal, not loud. Is that normal? Just got home & starting to look at manual & here - but if anyone knows what it could be please HELP I'm suppose to ride to Canada this next week!!! - OH No HELP Thanks |
my little silver box under the seat never makes any noise so i guess that could be your problem. I just thought it was a handy pedistal for my insurance card and registration papers.
1 Attachment(s)
What is this?
the ignition signal pulse? This is making the whining sound as mentioned in 1st post |
It is called a "converter unit". I do not know what it does. It is mentioned on page 17-3 several times as a possible culprit for No Spark electrical issues, and then through out chap 17. Take a look and run some of the tests. As for the whinning, chould be a lose circuit board connection aggravated by pulses.
I found this: http://www.vendio.com/stores/FastShi...f-cd/lid=70118 plus 6 others listed on ebay |
Originally Posted by residentg
(Post 268889)
That's the box responsible for the spark, simple explanation... And while it is possible that it's a connection like residentg said, I'd put my money on a blown capacitor... They typicly "whine" when they have failed and it's more likely than a loose connector since most parts inside would be potted and unable to move...
(Post 268895)
...I'd put my money on a blown capacitor... They typicly "whine" when they have failed and it's more likely than a loose connector since most parts inside would be potted and unable to move...
(Post 268895)
Is the capacitor in there or some where else? |
It's in there... Buried in potting material... Not something you want to play with removing... Usually you end up damaging something else before you get it all out and can fix what's broken in the first place... With the symptoms I'd say odds are good you can swap that box and keep riding... But I'd probably recommend going through all the electronics like R/R, stator battery an full harness and checking it before you do... Just to make sure the dead CDI is the cause and not the effect of your problems...
Is there a way to test the CDI??
How much is a new one? |
no way to test yourself, it is rare they break on a hawk though so not too much worries buying used one on ebay.
CDI $450 New
Converter unit $525 new some examples http://cgi.ebay.com/ebaymotors/Honda...Q5fAccessories http://cgi.ebay.com/ebaymotors/97-05...Q5fAccessories |
Originally Posted by cornandp
(Post 268919)
CDI $450 New
Converter unit $525 new some examples http://cgi.ebay.com/ebaymotors/Honda...Q5fAccessories http://cgi.ebay.com/ebaymotors/97-05...Q5fAccessories Nope - see my pic its not the CDI, but the converter box, but thanks for help I'm freaking out - I leave for F1 race Thursday & was planning on taking moto |
the second link is the converter box. I don' know why yours looks different, mine looks like the ebay link one.
(Post 268924)
Would the ICM be OK & the converter unit bad, or would the ICM cause the converter unit to go bad? As stated the converter unit was make a low noise I didn't check the ICM last nite. VTR is at friends house - about 1 hr away |
Worked with computers for years, take a sniff of the offending part. If it smells like rat piss on a hot grill with garlic, you've popped a capacitor ;) Those things could clear the work room when they went lol!
The Bandit 400's from Suzuki were prone to capacitor failure over time. I successfully swapped those out on mine, making a huge difference in starting / running etc. Getting to the board was the biggest trick, as they weren't really designed to be serviced. Involved a bit of chipping, cutting, melting and cursing. |
(Post 268921)
...I'm freaking out - I leave for F1 race Thursday & was planning on taking moto
JB |
(Post 268929)
ask the ebay sellers if they will overnight a unit to you. Whoever says yes, gets the buy.
JB 1. After talking to 2 moto mech. whom I know - one of which is a Hawk owner - the converter unit should NOT be making any noise. 2. Try to find a used one, as the cheapest I've seen a new 1 is about $380. OUCH. But the ebay ones I've seen the plug is mounted different from mine - see pic below http://i84.photobucket.com/albums/k1...0604002001.jpg 3. tomorrow on way to work stop by where bike is now & test the ICM to make sure that is OK. 4. Have parts over-nighted so I can be on road Thursday morning to F1 in Montreal!! on two, ready break |
1 Attachment(s)
what year is your bike? I have a 99 and an 05, I will look to see if they are different.
UPDATE: The 1999 unit has the plug on the flat / top side of the box The 2005 unit has the plug on the side of the box like the one in your photo. My guess - they are functionally the same. Honda only lists one part number: 30460-MBB-E30. The fiche shows the older flat side mount in the diagram (#32). Attachment 27325 |
If the older style unit will work on your newer bike, then this one here is from inderocker one of our esteemed moderators: http://cgi.ebay.com/ebaymotors/CONVE...Q5fAccessories
that is cheap insurance!
Inde can be trusted and knows his stuff. Several members here have done business with him (me too! - those damn wheels still haunt me) and he's a "get it done" guy. Airlines still do "next flight out" but you pay for someone to hand carry your part from counter to counter.
Glad it didn't just happen to me.....
Originally Posted by nuhawk
(Post 268946)
Also I doubt the CDI would fry the converter. Just my opinion though.
(Post 268935)
UPDATE: The 1999 unit has the plug on the flat / top side of the box The 2005 unit has the plug on the side of the box like the one in your photo. My guess - they are functionally the same. Honda only lists one part number: 30460-MBB-E30. The fiche shows the older flat side mount in the diagram (#32). http://i743.photobucket.com/albums/x...gHarness-1.jpg |
If it were me, I would ask inde to overnight his $19 unit, it will probably work and you can go on your trip. If not, relist it and buy a new one. Electrical issues are tough to diagnose and can be expensive. This is a cheap way out. My 2 cents. Study the wiring diagram in the service manual, see what you can find out.
Pat, buy Inde's and git r dun!
Originally Posted by SPRHK
(Post 268975)
I've already reached out to him |
I can confirm that they work when swapped between years... The only reason for the different design is that on the older ones they are mounted lying flat in the ass... On the newer ones they sit outside the subframe by the R/R... So the plug is mounted where it's easy to connect/disconnect... No other differences...
(Post 268935)
UPDATE: The 1999 unit has the plug on the flat / top side of the box The 2005 unit has the plug on the side of the box like the one in your photo. My guess - they are functionally the same. Honda only lists one part number: 30460-MBB-E30. The fiche shows the older flat side mount in the diagram (#32). http://i743.photobucket.com/albums/x...gHarness-1.jpg Well I just got the part - Note to All: Do Not use USPS to ship overnite - bought from Inde off Fleabay & since USPS needs a signature for their Express Mail - my mech just got the package, but had to pick up @ local PO - not really convenient, when UPS or FedEx just leaves it...I know a bit picky - but if it was delivered yesterday, then... I would have known 24 hrs ago that the part is different than mine. The plugs do not match!!!!!!!!!!! My mech is messing around w/ my plastic connector plug to modify so it fits - should know within the hr if it works Crossing fingers I'm suppose to leave tomorrow @ 7am for road trip |
| All times are GMT -7. The time now is 01:55 AM. |
