Having issues with my 2003 vtr1000f
I just recently started having issues with my bike. I ran a carb cleaner through my bike, and had all of my fluids changed about a month ago, and since then it started taking longer for my rpm's to stabilize when starting up my bike. But the real issue started a couple weeks ago when I was riding to work. Out of no where my rpm's jumped up to 2500, and started fluctuating. It sounded and felt like some kind of air leak. So I brought it to my mechanic, he pulled my bike apart and couldn't find an air leak anywhere. He also cleaned and synced my carbs, and cleaned my air filter today. Since that the bike has been running better, but the rpm's still fluctuate a little at idle, but not as much as before. My mechanic is stumped at this point, so I was wondering if someone here might have any idea of what's going on, and what I can do to fix it.
Cause of problems, "cleaned my air filter"
Originally Posted by xeris
(Post 399007)
(Post 399007)
: k&n, which, for many members, has caused carb tuning problems, I believe, is what xeris is alluding to. |
Originally Posted by Aquasnake
(Post 399009)
That it is a cleanable air filter, i.e.
Is your current dirty (but hoovered) airfiter a disposable OEM type or a K&N?
As mentioned a K&N despite its advatages in being cleanable & reusable, will play havoc with the carburetion and need time and cost up to & inc rejetting and dyno time to give modest gains. Best go OEM. |
Originally Posted by InkinSteven
(Post 399015)
Oh OK, well I thought that might possibly be a problem, and I plan on buying a new air filter, I just lack the funds for it ATM. I didn't even know I needed a new one until my mechanic started pulling my bike apart to get to the carbs, and when he got to the air filter it was disgustingly black. So he just did that to last me a week or two until I could afford to get a K&m filter.
I don't have a k&n filter, it's just a stock filter. Do you think that my bike will start running better once i get the air filter replaced?
Are you starting it with choke? You should check you choke cables, they tend to bread at the elbow and really mess with jetting (figuratively) so it wont settle into idle.
Basically it is an enriching circuit that with broken elbows it runs super rich all the time. Sometimes only on one cylinder. |
Before I read on this forum that it was a bad idea, I installed a K&N air filter on to my VTR1000F. This has been absolutely fine, the bike runs great, no re-jetting.
(Post 399112)
For sure put the new filter on to see if that helps, but from your description I would guess you want to clean the carbs. Before doing this you could check the choke cables just to see if they are perfect (they rarely are)
(Post 399167)
