elijahawk |
09-19-2007 09:38 AM |
having big problems with my SH
what happened was the cam chain snapped while i was riding and the piston came up and bent the valves so i replaced the cct but with the stock one again cause the macanic is dumb. put knew valves and that in. he buttoned it back up. that was a month or two ago, when i got it i noticed when i was getting on the throttle it was bogging and cutting out at about 6500 rpm and there was a loud clicking and jolting at lower rpm around 3000. so he told me that the valves needed to seat and to run a couple of tanks through it. i took it back cause it was still doing it and he said it was the cdi box. than i came here and seen some guy had a timing problem and it sounded about the same problem as mine, with it hesitating and stuff. so i took it back to him again and he says the timing is perfect. please help.
