Has any body used Aftermarket Clip Ons? I have a 03 SH.
I went down and i'm trying to rebuild my sh. I see clip ons on amazon, will they work. To my knowledge all i know is i measure the diameter. Please help??
As long as they are the right diameter (fork diameter) they should work. You may have to drill a couple of index holes for the controls. Just copy the locations and sizes from your stockers. You may also have to adapt some bar end weights.
Thank you, i am going to go stock bars. I'm trying to get her back stock. When i bought here she was a ugly street fighter.
iv used VFR750/800 which are about an inch higher, also suzuki sv650 bars bolt straight on and are more comfy than standard.
Originally Posted by fabiostar
(Post 405587)
VFR clipons works way better and comfy. |
A set of clip ons is the way to go. You can reverse the yoke and it will rise upwards instead of dropping down, and if you mount them on to of the triple trees, it will be even higher but a bit more aggressive steering, If you ever go down again, the replacement tubes are super cheap. I always kept one in my tool box whenever I competed.
(Post 405587)
OP, if you need them, I can sell them pretty cheap. Possibly have more of what you need as well. PM me. |
