SuperHawk Forum
-   -   Hard Shift into 2nd (https://www.superhawkforum.com/forums/technical-discussion-28/hard-shift-into-2nd-11378/)
DocPigskin17 May 8, 2007 08:40 AM
Hard Shift into 2nd
My 98 SH sometimes has a hard shift into from 1st to 2nd gear. If I lay on the throttle hard in 1st in is hard to get into 2nd (wants to shift into neutral). I am going to change the clutch fluid today but if that doesn't do the job, any suggestions as to what to do next?:nerd:
mikstr May 8, 2007 08:47 AM
I think all VTR's are notchy shifters between 1st and 2nd
Zedicus May 8, 2007 09:30 AM
clutch fluid??
theres a shift kit thas spose to help.
theres heim joint kits for the shift rod.
some peeple hav luck moving the shifter up a notch.
RPV-Hawk May 8, 2007 11:28 AM
Originally Posted by Zedicus (Post 52071)
clutch fluid??
It's a Hydraulic actuated clutch...remember:lol:
RickB May 8, 2007 12:17 PM
I have the factory pro shift kit in my SH and it did help the 1-2 shift. I have the cheaper $80 version not the evo shift star, just a rod with a ball bearing roller and a spring.
The Hawk Guy May 8, 2007 05:11 PM
I think this is a very common problem on the superhawks. I noticed the difficulty of shifting into 2nd the first day I rode it (the bike was nearly brand new). Try to find the sweet spot and shift at the right RPM.
Hawkrider May 8, 2007 05:37 PM
Change the oil to something good (if not already done) and short shift the 1-2 gear change. It shifts smoother at lower rpm. After that shift higher if you like.
flyin_hawk May 8, 2007 07:46 PM
Pre-loading the shifter helps a lot.
shayne May 9, 2007 04:25 AM
Don't put up with it, do the mods. That is my opinion.
The Factory Pro kit is worth a fair bit, but it is a very significant upgrade to the quality of the OEM components.
Moving your linkage to change the shift throw is free and easy to do.
The heim joint mod is my own as far as I know, and works well. Not sure how many other people have done it since I mentioned it, but I think there have been a couple. Isn't too hard to do, and the parts are cheap enough. Don't underestimate the effect that quality, well lubricated joints, will have on the shift.
midijunky May 9, 2007 06:59 PM
+1, I had shifting issues that I thought were gearbox issues. I changed oil to a known "good" shifting oil, did the heim mod and the spline mod, shifts better now. Still doesn't enjoy shifting into 2nd when you're Really into it, but it's not as bad now.
