Guage dilemma
So I am installing an aftermarket dash. The speedo uses a sensor on the front wheel but the tacho I plugged into the stock harness. It reads ok up to like 4k rpm but beyond that goes to zero.
I have experimented with the winding around the spark plug wire method but it didnt seem to work well. Has anyone done it a different way & had success? |
Does it seem accurate up to 4K or when the bike is at 8K or 2K it reads 4K?
It is accurate to 4k but if you rev beyond 4 it goes to zero on the guage. (which is how I initially worded it)
