Gauges and instruments don't work after crash...
Had a little wipe out bike works fine but my lights, dash etc dont light up or show on the lcd.... could it be just bulbs??? anyone know how to change these or had any problems like mine ????
Signal lights flash but oil light, nuetrel light, high beam light and lcd for trip meter dont show up and tach and speedo dont light up
Sorry to hear of your mishap - glad that you're OK. Kinda sounds like a wire harness connector or connectors came loose or pulled out under the gauges. May want to double check your fuses as well. If 1 or 2 bulbs were out I might suspect blown bulbs but this sounds like more than that.
Where are the fuses? I tapped it a few times but I am goint to look at the fuses and the wiring when I replace the fairings.....
Download the service manual and use it. It shows where all the fuses are and what they are for. Do a search for it here.
Ok yeah its the fuse but soon as I change the fuse it goes out again and blows a fuse............... now what???
also is it hard to replace bulbs in the gauges??? |
If it blows the fuse repeatedly you have a short somewhere. You will need to trace out the wiring to locate the problem. Use the wiring diagrams in the service manual to help you determine what is running off that fuse that keeps blowing. You may want to remove and unplug the gauge cluster - if the fuse doesn't blow with that disconnected its a problem within that unit. I would guess the bulbs are easily replaced but I have not done it on a superhawk. It could be a shattered bulb that has shorted out. Also look for any damaged wires, connectors, etc that could be shorting to the frame. Its probably an easy fix once you find where exactly the problem is.
Ill have to take a look when I do my repairs thanks
everything works now with the bodywork off so must have been punched somewhere
