Gas everywhere
I am new to my 98 VTR, but am no 'fall down' when it comes to mechanics. I had my vtr set up by a pro shop that had all the gear to get my air/fuel right on and everything was fine for a few weeks. Then it started to run like crap at idle and low rpms, sputtering and such. I went out the other day and there was gas all over. My tank has all but emptied into the cylinder through my carb and leaked all over. Not sure whats going on here. Any help is appreciated.
Your petcock diaphram failed and also a float valve in your carb failed. DO NOT attempt to start your engine, because you could hydro-lock it.
You will need to get the gas out if the cylinder, do an oil change, repair your petcock, and fix your float valve. |
Originally Posted by CruxGNZ
(Post 396853)
Dr.G
Your issue has happened before to other members here and Crux hit the nail on the head. I'm sure you have a mess to deal with. At least you know exactly where to look. |
For the petcock diaphram, look to eBay.
1997 2005 Honda Superhawk VTR1000F VTR1000 K L Fuel Petcock Repair Kit 18 5015 | eBay For the float valve, check out Partzilla. They usually have the cheapest prices. 16155-MBZ-K31 VALVE, FLOAT $15.57 Part #16155-MBZ-K31 Which ever cylinder filled with fuel, the carb that attaches to it is the one that needs the float valve. The service manual, found here in the Knowledge Base, will help you to fix these issues. |
(Post 396858)
1997 2005 Honda Superhawk VTR1000F VTR1000 K L Fuel Petcock Repair Kit 18 5015 | eBay For the float valve, check out Partzilla. They usually have the cheapest prices. 16155-MBZ-K31 VALVE, FLOAT $15.57 Part #16155-MBZ-K31 Which ever cylinder filled with fuel, the carb that attaches to it is the one that needs the float valve. The service manual, found here in the Knowledge Base, will help you to fix these issues. Thanks brother. I will look into that. I appreciate your time and advice. |
(Post 396858)
1997 2005 Honda Superhawk VTR1000F VTR1000 K L Fuel Petcock Repair Kit 18 5015 | eBay For the float valve, check out Partzilla. They usually have the cheapest prices. 16155-MBZ-K31 VALVE, FLOAT $15.57 Part #16155-MBZ-K31 Which ever cylinder filled with fuel, the carb that attaches to it is the one that needs the float valve. The service manual, found here in the Knowledge Base, will help you to fix these issues. The float valve should just pull out when I remove the float, correct? |
Should
So, I did my float valves and I took my petcock apart, but there was no damage to the diaphram. I have a rebuild kit coming either way, but my question is, with the petcock in the open position, should gas come out to the carbs? Or is it on vacuum demand?
It is vacuum operated. As soon as you turn over your engine, there is a vacuum and this vacuum, for lack of better words, turns on the petcock.
EDIT: Make sure the vacuum line is attached to the nipple on the back of the petcock. It does not attach to the nipple on the bottom of the petcock. |
(Post 397183)
It should not do that. Even with the vacuum line removed from the back of the petcock, gas should not flow when turned to "ON".
Pull your petcock off and you will see how it works. Super simple. Engine turns over creating vacuum. This vacuum "sucks" the diaphram allowing fuel to flow. If your petcock has fuel flowing without vacuum, them something is definitely wrong. |
(Post 397185)
Go in a dark room and shine a flashlight through the diaphram. You will posibly see a very small pin hole. If you don't see a hole, then the diaphram was possibly not seated properly in the petcock alowing a vacuum leak.
Either way, going off you original post, your petcock was not working correctly. |
(Post 397187)
