Fuel Tank sender unit
Hi guys, I’m in the middle of cleaning out a rusty (surface only) fuel tank on an ‘03 VTR1000f - the fuel guage was working fine prior to taking the sender unit off the tank....I’ve got the tank ready to go now and thought I’d just check the sender unit again before bolting it back onto the tank so I connected it to the wiring harnesses and moved the float up and down...the guage on the dash doesn’t seem to change, in other words it just reads empty - flashing- I went ahead and connected it to a multimeter- moves the float up and down and it definitely reads differently according to the float position.....what am I doing wrong????...thanks in advance for your help. Mark |
Originally Posted by MarkJet
(Post 408278)
Hi guys, I’m in the middle of cleaning out a rusty (surface only) fuel tank on an ‘03 VTR1000f - the fuel guage was working fine prior to taking the sender unit off the tank....I’ve got the tank ready to go now and thought I’d just check the sender unit again before bolting it back onto the tank so I connected it to the wiring harnesses and moved the float up and down...the guage on the dash doesn’t seem to change, in other words it just reads empty - flashing- I went ahead and connected it to a multimeter- moves the float up and down and it definitely reads differently according to the float position.....what am I doing wrong????...thanks in advance for your help. Mark If not that, and you have in valve spec readings from the sender on the bench...perhaps its a wiring issue between connector (pushed out pin?, broken wire at the back of the connector?) |
Thanks for the reply, yes I did earth it out when I connected back up to the bike...can’t work out what’s going on with it, and all connections seem to be fine.... |
Ok worked it out, nothing wrong with the sender unit...when connected, and you move the float up and down, it takes awhile for it to show on the dash guage - obviously to compensate for the fuel moving around within the tank when riding/leaning into corners etc. 👍🍺 |
(Post 408288)
Cheers mate |
