front wheel removal??
hello to all, I have a front stand that fits in the holes under the forks to raise the front wheel off the ground. I need to remove the front wheel to have a tire mounted. can I remove the front wheel while up on this stand? I'm guessing the fore mentioned holes don't open enough to have the bike fall off? has anyone used these stands and removed the front wheel??
Thanks in advance,Neil |
Yes, you can use that stand, provided you have it on a rear stand as well. I have one and I've used it many times just for tire changes.
thanks Greg thats what I wanted to hear:kneel:
