Front sprocket
I was just cleaning my drive chain and found out theres a little bit of play in the front sprocket. The play is side to side like if there was missing a washer. I checked in the maintenance manual and there should only be one washer...which I have. Has anyone run into a similar problem? Is this common to this bike? This is the first time I have taken these apart and I want to make shure there's nothing missing. Thanks in advance.
I replaced my chain and sprockets recently. I did measure .011" freeplay on the stock sprocket, and my aftermarket replacement had about .014".
So to answer your question...yes it is normal. |
Thank you very much.
I was wondering the same thing the other day when I was cleaning the bike could not remember when I switched the sprockets thanks for asking saved me looking it upl
