front fork spring rates.
Old Jan 2, 2013 | 09:37 PM
jcvtr's Avatar
jcvtr is on a distinguished road
Hi guys. I am planning (and ordered a 6mm spacer for the rear shock.)
The question is what spring rate do i order for the front fork?
my weight is 220 pound without gear. the bike is used regularly for riding to work. with the occasional (intend ) for trackdays. what weight shd i go for?
I am inclined to 0.9kg/mm. what do u guys think?
Old Jan 2, 2013 | 10:35 PM
There is no cut and dry answer. It depends on your riding style and what "feels" right to you.
For most riders in your weight range 0.9 -0.95kg\mm seems to work fine.
Though to give an example, when I was running the stock forks I ran 1.05kg\mm springs because I tend to brake late and that is what worked best for me.
One thing I will say is you will need to have the valves set for whatever spring you install.
Old Jan 3, 2013 | 02:29 AM
jcvtr's Avatar
Thanks man. I figure i have to do both or us leave it stock.
Old Jan 3, 2013 | 03:40 AM
I agree with Mike. YOu can check both the Race Tech and Sonic springs web sites as they have rate calculators to help with this type of thing. Curiously, RT recommends slightly stiffer springs than Sonic does.....
Old Jan 3, 2013 | 06:31 AM
JamieDaugherty's Avatar
Pretty straighforward:
115-150lb > 0.80kg/mm
150-180lb > 0.85kg/mm
180-215lb > 0.90kg/mm
215-250lb > 0.95kg/mm
250-280lb > 1.00kg/mm
This applies to everyone for street and track. The only exception would be an expert track rider on race tires. I've only ever found it necessary to deviate from these rates for VERY special circumstances, so almost never.
Now, if you are on the edge, say 180lb, then you need to make a decision. For most street riders I will go softer unless they are fairly aggressive. Being on step off of ideal is probably not the end of the world but it's best to try and "get it right" if you can. For you = 0.95kg/mm.
I've found +6mm at the rear shock to be a bit much. I think for an otherwise stock bike it makes the handling "feel" better, but +3mm is what I suggest. If you go +6mm now that would be ok, but with other changes (springs/valving in shock and valving in the forks) you will want to drop down for best results.
I hope this helps!
captainchaos
Jan 8, 2010 09:20 AM
hawk28
May 31, 2008 09:22 PM
roisman
Mar 25, 2008 10:43 AM
speedkelly@aol.com
Jul 18, 2007 06:00 PM
filter_jam
Apr 12, 2007 02:18 PM
