SuperHawk Forum
-   -   front fork rebuild (https://www.superhawkforum.com/forums/technical-discussion-28/front-fork-rebuild-24371/)
vtrwillie72 Dec 18, 2010 01:46 PM
front fork rebuild
Hey Guys,
Now that there is snow on the ground I am planning on tearing the front end of my bike apart & rebuilding the front forks. I am planning on replacing all the "wear" items as my bike is pushing the 50,000 mile mark. Other than seals, bushings & orings what should be replaced?
Thanks
8541Hawk Dec 18, 2010 03:53 PM
The springs and the valves, if they haven't been set up for your weight. Other than that, try to pick up a fork brace and you're all set. ;)
and you left changing the fork oil off your list......:cool:
vtrwillie72 Dec 18, 2010 04:48 PM
I can't re-use the fork oil? :rolleyes:
Tweety Dec 19, 2010 01:14 AM
You can try... ;)
